Segmentation fault problem in Embedded system
Shreehari
Member level 4
Member level 4
mangalore
Hello
I had written a code to read the digital output of my embedded system.and compiled i through the GDB.and executed in target system.But it gives Segmentation fault error.My program is simple and is written below...
the value is a file located in do5 file.
#include<stdio.h>
main()
FILE *file =fopen("/sys/class/sbc2800/d05/value","wt");
fprintf(file,"1");
fclose(file);
Pls rply ..I am using ARM 9 processor.and logged as root. and also please tell me how to generate the executable in tiny model(like compact,small,medium,tiny).
Regards
But several documents says supports "t" mode.I had seen some documents in internet.Your link doesn't work.
Also the Embedded system manual also tells the same.
ok I will work with simple "w" mode and let me tell you the result.
Added after 3 hours 33 minutes:
I had written 'w' inplace of 'wt ',but still segmentation fault comes...
Try to know which line gives the segmentation fault, in order to remove the error.
Add some printf or use a debugger.
Amr
    Shreehari
Do not assume that the file was successfully opened. If fp is NULL, you will get segmentation fault. You need something like:
if(file) fprintf(file,"1");
if(file) fclose(file);
Try this. Does it still give segmentation fault or does it complete ?
Kennedy
