Segment Over Void Check for Altium Designer 15 PCB
ivan27807
Junior Member level 2
United Kingdom
Does any one know if there is a feature in Altium Designer 15 or can someone recommend filter "line" to easily detect the following case:
* High Speed track as microstrip that has a segment that run over discontinuity in reference plane (example running over a gap on the split plane reference or large polygon voids created by some high voltage thru hole pins).
* High Speed track as stripline that has a segment that run over discontinuity in reference plane either above or below (example running over a gap on the split plane reference or large polygon voids created by some high voltage thru hole pins).
I recall in Cadence Allegro there is a feature known as "segments over void" which detects these case with ease. I am new to altium and I had to check meticulously each high speed track to make sure not one did cross a void.
Thank you in advance.
