seeprog schematic and pcb
tps_star
Full Member level 1
Full Member level 1
hi
i need 100% working pcb and schematic for seeprog programmer
and any freind have orginal seeprog programmer if ok please take picture from main board this programmer and upload
please helpme
thancks
thancks
i have your sending pcb and schematic and make but can not working
i see file and i make pcb and part but can not work
i connect to software and choice device and program
but when i will program device
program=ok
verify=error
and my chip is empty
Don't tell me that you made the double sided PCB in less than two days? If you really did it, check all your connections on components where signals are changing layer. You might miss some places to solder.
HTH
no i make double sided pcb in Last week
i check all connection and components is ok
you make this schematic ?
if ok please giveme your pcb
and i make smd board and use Instead of this component other components
BAT85 USE BAS85
BCX17 USE BC807
BCX19 USE BC817
is possible do not work my programmer Because i use BAS85 Instead of BAT85 or not?
It makes no difference as far as the diodes and transistors. Same beasts :), different packages.
I do not use Seeprog, I rarely have to fiddle with SEEPROMs in ready made devices.
If I have to make some corrections, as I'm using mainly 24Cxx SEEPROMs, I use Willem programmer.
your willem programmer pcb version is how?
What ICs did u use? As far as i remember, all have to be HC version, not LS!!
Please, PM me sch to compare with mine
