Seeking for a good SDRAM tutorial
cyc
Member level 1
Member level 1
sdram tutorial
Hi!
I am seeking for a good SDRAM tutorial.
sdram tutorials
May be this is helpful to u.....
video tutorial of sdram
Look at the Micron Data sheets for it's SDRAM Devices. data sheets are really complete. They have explained every point you need to know about SDRAMs Clearly.
sdram toturial
You can find a good ebook about memory in MCU Fileman.
8)
sdram design tutorial
Hi mami_hacky,
Yes, I have read one of Micron's datasheet. I understand the basic read/write access, reflash. I would like to know more detail about "precharge". Why precharge?
The datasheet saids " The PRECHARGE command is used to deactivate the open row in a particular bank or the open row in all banks. The bank(s) will be available for a subsequent row access a specified time (tRP) after the PRECHARGE command is issued. "
I am confusing with the key word "deactivate".
micron sdram tutorial
Hi horzonbluz,
Would you please show me the full path of the ebook?
Thanks!
sdram tutorial precharge
Hi
The above pdf can also be downloaded from
h**p://www.kingston.com/tools/umg/umg2000.pdf
Thanks.
