security with grid dip meter method
psmeets
Junior Member level 1
grid dip meter schematic
I want to build a security system which detects when an object is 'out of reach'. The range should be 1,5 - 2 meter.
What about the grid dip meter method? When the object (with the LC resonator inside) leaves the area, the electromagnetic field changes.
Does anybody have a schematic? I prefer to make the reader and the tag myself.
Patrick
grid dip meter
This method relies on inductive coupling. The range will be a few cm unless both coils are very large. By large I mean a diameter of at least half the distance you want to cover.
This may not meet your needs. If you can have a battery in the object things are better. You can receive a signal at frequency F and retransmit it at F/2 and get much more range with smaller coils.
grid dip
What kind of OBJECT .. a PERSON ?? or a thing
There is the Thermic RADIATION method is pretty good .. you can detect
temperature variations with thermopiles!
