security safe box with using PIC16f877a
emperror123
Member level 5
Member level 5
dear all
currently i am doing on program which is safe box by using PIC16F877a
i got the key pad program which i write it b myself
following are my code
list p = 16f877a
#include p16f877a.inc
__CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _PWRTE_ON
lcd_RS equ 1
lcd_write equ 0
lcd_op equ PORTD
kpad_pat equ 20
kpad_add equ 21
kpad_op equ 22
kpad_char equ 23
			org 00
			goto start
			org 04
			call interrupt
start 		bsf STATUS, RP0
			clrf TRISC
			clrf TRISD
			movlw B'11110000'
			movwf TRISB
			bcf OPTION_REG, NOT_RBPU ; enable internal power in PORTB
			bcf STATUS, RP0
; kaypad program
			clrf PORTB
			bcf INTCON, RBIF
			bsf INTCON, RBIE
			bsf INTCON, GIE
loop		goto loop
interrupt
kpad_to_lcd	call kpad_rd
			call kp_code_conv
			bsf PORTC, lcd_RS	;ques
			movwf lcd_op		;ques
			call lcd_write
rel_test	call kpad_rd
			movf kpad_pat, 0
			andlw 0xfe
			sublw 0xfe
			btfss STATUS, Z
			goto rel_test
			bcf INTCON, RBIF
			retfie
kpad_rd		movf PORTB, W
			movwf kpad_pat ;ques
			bsf STATUS, RP0
			movlw B'00001110'
			movwf TRISB
			bcf STATUS, RP0
			movlw 00
			movwf PORTB
			movf PORTB, W
			andlw B'00001110'
			iorwf kpad_pat, 1
			bsf STATUS, RP0
			movlw B'11110000'
			movwf TRISB
			bcf STATUS, RP0
			clrf PORTB
			return
kp_code_conv	bcf STATUS, C
				rrf kpad_pat, 1
				clrf kpad_add
				btfsc kpad_pat, 6
				goto kp1
				goto col_find
kp1			btfsc kpad_pat, 6
			goto kp2
			movlw B'00000100'
			iorwf kpad_add, 1
			goto col_find
kp2			btfsc kpad_pat, 4
			goto kp3
			movlw B'00001000'
			iorwf kpad_add, 1
			goto col_find
kp3			btfsc kpad_pat, 3
			goto kp4
			movlw B'00001100'
			iorwf kpad_add, 1
			goto col_find
kp4			movlw D'16'
			goto keypad_op
col_find	btfsc kpad_pat, 2
			goto cf1
			goto keypad_op
cf1			btfsc kpad_pat, 1
			goto cf2
			movlw B'00000001'
			iorwf kpad_add, 1
			goto keypad_op
cf2			movlw B'00000010'
			iorwf kpad_add, 1
keypad_op	movf kpad_add, 0
			call kp_table
			movwf kpad_char
			return
kp_table	addwf PCL, 1
			retlw '1'
			retlw '2'
			retlw '3'
			retlw 'A'
			retlw '4'
			retlw '5'
			retlw '6'
			retlw 'B'
			retlw '7'
			retlw '8'
			retlw '9'
			retlw 'C'
			retlw '*'
			retlw '0'
			retlw '#'
			retlw 'D'
			retlw 'E'
end
since i got it, but i now confused how to put the coding for LCD display code and servo motor code in my code, since i have cracked my head for many days still remain unsolve
2nd is i wan to have a schematic diagram for safe box which is consist of PIC16f877a, servo motor, keypad and LCD display
a lot of article draw with seperately, and i unable to use which 1 to do it,
thank, and ur help is much appreciated
