secure rf communication
vksh
Newbie level 6
Newbie level 6
Plz help me
I m doing my project on secure rf communication
Using at89s52 keypad or LCD or rf antenna
Plz provide me source code for both tx and rx
Hey... try to do it yourself , you will get lot of tutorials about using the serial port , lcd interfacing etc from the internet.
Its so easy to learn 89s52 programming. If you want to use wireless communication you can prefer zigbee or 433Mhz rf module, both works on the uart of the uC.
Anyway here i am attaching a code containing basic functions for lcd interfacing and serial port configuration, edit it as your need
#include<REG51.h>			//LCD DATA P1    RS= P2.0,RW=P2.1,EN=P2.2
void DELAY(int);
unsigned char ASCII(unsigned char);	//funtion to convert hex to ascii
void LCD_COMMAND(unsigned char);
void LCD_DATA(unsigned char);
void LCD_STRING(unsigned char *VAR)
 	while(*VAR)
	LCD_DATA(*VAR++);
void main()
TMOD=0X22;
TH1=0X00;
SCON=0X50;
LCD_COMMAND(0X38);
LCD_COMMAND(0X0C);
DELAY(100);
while(1)
void DELAY(int C)
TF0=0;
TR0=1;
for(I=0;I<C;I++)
while(TF0==0);
TF0=0;
void LCD_COMMAND(unsigned char DATA)
P1=DATA;
P2_0=0;
P2_1=0;
P2_2=0;
P2_2=1;
DELAY(60);
P2_2=0;
void LCD_DATA(unsigned char DATA)
P1=DATA;
P2_0=1;
P2_1=0;
P2_2=0;
P2_2=1;
DELAY(60);
P2_2=0;
 unsigned char ASCII( unsigned char temp)
	if(temp>0x09)
	temp=temp+0x07;
	temp=temp+0x30;
	return(temp);
Reactions: vksh
    vksh
I hv tried
But I m poor in programming
And in next two days I hv to submit my minor project
In which I hv to show data transmission on proteus
Pl help me
I hv tried
In which I hv to show data transmission on Proteus
Pl help me
Put up your simulation and code you write and problem you are having with out that its like shooting in the air for others and hard to help you. provide more information for helpful answer.
Reactions: vksh
    vksh
Explain your needs clearly , i can help you
Reactions: vksh
    vksh
I want to devlop my project
Secure rf data transmission on proteus software
Using two mco at89s52
Keyped , lcd , rf module
I want source code for both tx mco , rx mco
Milan.rajik
Provide me a code but it is not complete
Spacially for tx because it not contain input method like keyped
And it dose not secure comm.
Plz hel me
Here is the attachment
http://www.datafilehost.com/d/32c84ab7
Milan.rajik
Plz hel me
https://www.datafilehost.com/d/32c84ab7
Please try bye yourself and show the work you have done first for start you can do many sample code on google using that make your application code and then if you get any problem then come up with that problem.
Please start your work and share it so others can help..
https://www.codeproject.com/Articles/55864/Remote-control-based-on-c-with-MHz-radio-mo
Reactions: vksh
    vksh
