Searching for low NF Agilent or NEC BJT
adnan siddqui
Newbie level 5
Newbie level 5
searching for low NF BJT
Please provide me the part no. of @gilent or NEC 's BJT having low noise figure i.e. 0.5db-0.7db at 2 ghz.
Re: searching for low NF BJT
agilent or philip have low NF bjt
You should try the agilents ATF54143 Enhancement mode FET, it requires a +ve voltage on the gate and is very easy to use (match) as well as it is quite stable.
I HAVE SEARCHED IT BUT NOT FOUND BELOW NF 1.2 db
I have uploaded selection guide. Please look at that.
Try the SiGe BFP series from Infineon. Better than Agilent or NEC, and cheapper.
regards
