Search&Replace "Multi-line" text in multiple f
mask_layout
Member level 2
Member level 2
I am replacing a single line text with multiple line text. I will be doing this for about a hundred files and I think its crazy to work on it 1by1.
Im new to shell scripting in unix and cant get the following command to work on replacing single line to multiple lines.
#!/usr/local/bin/tcsh
foreach file (*.TECH)
   set newname=`basename $file .TECH`
   mv $file $newname"_DFM.TECH"
   end
foreach DFMfile (*_DFM.TECH)
  cat $DFMfile | perl -pi -e "s/OneLinerOldText/NewMultipleLineText/g;" >$DFMfile
end
This is my sample INPUT FILE
block "xxx"
line1 = 0
line2 = 0
OneLinerOldText = 0
line3
line4 }
NEW FILE I want to OUTPUT
block "xxx"
line1 = 0
line2 = 0
NewMultipleLine1
NewMultipleLine2
NewMultipleLine3
line3
line4 }
Can somebody help me to get this working please?
Re: Search&Replace "Multi-line" text in multip
In Unix shell, if you write in command line
cat FILE | echo >FILE
Then you would got an empty file. Because they clear the FILE first.
Therefore, just use a intermidiate file to prevent the mistake:
foreach file ( *.TECH )
end
set ext=.ext
foreach DFMfile ( *_DFM.TECH )
        cat $DFMfile | perl -pi -e "s/OneLinerOldText/NewMultipleLineText/g;" >$DFMfile$ext
        mv $DFMfile$ext $DFMfile
end
Hi wstu,
thanks for the reply.... ur script made it better... thanks thanks..
anyway, my real problem is that i cannot print in multiple lines... my output is always placed in a single line. I tried sed, grep and perl.... none works... or maybe i dont know the correct syntax...
im trying to use "\n" but it only prints as output.
's/oldonelinertext/new\nNew\nLiner\nText/g';
does not output
new
New
Liner
Text...
:cry:
[/b]
