magnetic zigbee sensor
About Sensor
A range of miniature digital output magnetic sensors that combine high levels of sensitivity with low POWER operation has been unveiled by Toshiba Electronics Europe (TEE). On 10 Septermber 2008
The TCS10xxx- family of devices is seen as ideal for non-contact switching applications including open / close sensing for home appliances, digital cameras and mobile phones.
Devices in the new family are available as single- or dual-detection solutions. While the single type is designed to detect either north- or south-pole the dual type detects both north and south poles. Supplied in a UFV package, each sensor has dimensions of just 2mm x 2.1mm x 0.7mm.
The sensors use a pulsed-current rather than continuous-current operation to keep typical average supply current down to just 5.5µA. All of the devices offer high sensitivity - typical operating point (BON) and release point (BOFF) magnetic flux density ratings are 1.8mT and 0.8mT respectively.
The TCS10xxx devices are based on a CMOS Hall sensor solution and are available with push-pull and open drain output configuration, says the company.
I Need your Comments on Usage
Might Be funny questions but please guide me
I am not sure about Flux range of this sensor No Data sheet with me.
Is it possible to detect heavy metals static equipment like parked vehicles, Docked Containers. Logically i am wrong but is there any way ?
Can i share same power Supply with ZigBee on single source
Is there any same low power consuming sensor with extended flux range ?
My reaserch is to develop wireless Parking/Container management system. I am in search of low power consuming (Like ZigBee) Sensor.
Thank You
Pcup.....
