SDF simulations are passing but noSDF is failing (SimVision).
Ramo.
Newbie
Newbie level 1
I'm running simulations but i noticed that noSDF simulations are failing, although simulations with SDF are passing.
For an instance I know that SDF simulations are the closest to silicone, so we can neglect the noSDF that are having mismatches. But i want to go to the bottom of this issue to remove this problem in my case.
I think that it must be the simulator (I'm using Cadence SimVision), it has some problems scheduling 2 events happening at the same time.
Do you have any idea why this might happen?
Cadence is quit new to me ( I used modelsim before), in modelsim the solution was to add nospecify option.
Do you know if there is a similar option in SimVision?
If the design is all synchronous. It should not happen.
There must some delay related design blocks, which does not have a proper simulation delay in RTL.
