ranaya
I am trying come up with proper clock constraints for a mux/div clock paths.
The design structure looks like below:
pll4x_clk is an input to the block, so that the output Tosch of the block has pll4x_clk/2, 4 and 8 options.
How to properly write the constraints in a way clocks are nicely converged ?
From this point onwards how to specify the multiplexed paths for Tosch ?
Thanks in advance.
create_clock -name pll_out4x_clk -period 5.00 [get_ports pll_out4x_clk]
#pll4x divided by 2, 4, 8
create_generated_clock -name clk_div2 -divide_by 2 -source pll_out4x_clk [get_pins fast_div2/clk_div2]
create_generated_clock -name clk_div4 -divide_by 2 -source [get_pins fast_div2/clk_div2] [get_pins fast_div4/clk_div2]
create_generated_clock -name clk_div8 -divide_by 2 -source [get_pins fast_div4/clk_div2] [get_pins fast_div8/clk_div2]
set_clock_groups -logically_exclusive -group clk_div2 -group clk_div4 -group clk_div8
Thanks in advance.
