[SOLVED] SD Ram and PIC comminucation
vishy71
Full Member level 2
Full Member level 2
Iran
Hi
I have so much question :oops:
can you help me to make communication between PIC and SD rams?
tnx
Here's a couple of PIC SD card projects in assembly language, I assume you still desire ASM over C:
SD Memory Card Interface
BigDog
Hi
thanks but this is not enough!
What else do you need?
---------- Post added at 15:06 ---------- Previous post was at 14:17 ----------
Checkout the SD Association's Site for specs:
SD Association
Hope the additional info helps in your endeavors.
oh tnx
may be this files help me
i close the threat and if i find problem i will come back
tnx
I may have additional PIC examples in assembly, if I find them I'll post them for you here in this thread.
BigDog
Reactions: vishy71
    vishy71
Hi
:oops::oops::oops::oops::oops:
can you give me youre example plz?:oops::oops:
thnaks:oops:
What PIC are you using, 16F877A, 18F4550, etc? Do you have a SD Card breakout board?
Like this:
SD/MMC Card Adapter
SD and MMC are usually 3.3v, so you need to take that into account when designing your circuit.
BigDog
Reactions: vishy71
    vishy71
Hi
I need a project about using SD card with PIC in assembly language.please help me
check this **broken link removed**
---------- Post added at 23:01 ---------- Previous post was at 23:00 ----------
MMC to PIC 3.3v Schematic
---------- Post added at 23:07 ---------- Previous post was at 23:01 ----------
