DWC
Newbie level 1
- Joined
- Sep 13, 2006
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- South Africa
- Activity points
- 1,291
pic18f sd card
Hi
I am currently stuggeling to get my SD Card to interface with my PIC18F4550. I keep on getting a ERROR in Hyperterminal:
Test MMC driver
mmc init fault
Start...
I am using CCS compiler and interface the SD Card and MMC card via SPI. I just want to write data to the card and read it back via rs232. I included the circuit diagram as well as the code. Can SOMEBODY help me please?
Thank you
DWC
and the MMC driver Driver:
Hi
Test MMC driver
mmc init fault
Start...
Thank you
DWC
#include<18F4550.h>
#device *=16
#use delay (clock=4000000)
#use rs232(baud=9600, xmit=pin_c6, rcv=pin_c7, errors)
#fuses HS, NOLVP, NOWDT, PUT, BROWNOUT
#define MMC_CS PIN_D0
#define MMC_CLK PIN_D1
#define MMC_DI PIN_D2
#define MMC_DO PIN_D3
#include <mmc_spi.c>
int buffer[512];
int16 size=0;
main()
int32 address=0;
int *ptra;
int16 f;
unsigned int a=0;
ptra = &(buffer[0]);
printf("\n\rTest MMC drivers\n\r");
printf(a);
if(mmc_init()==0)
printf("\n\rmmc init ok\n\r");
else
printf("\n\rmmc init fault\n\r");
enable_interrupts(int_rda);
enable_interrupts(global);
printf("\n\rStart...\n\r");
while(1)
a = mmc_init();
//starts to record the serial data and when have 512 bytes records it
if(size==512)
disable_interrupts(int_rda);
//prints the buffer
printf("\n\rWhat enter the buffer:\n\r");
for(f=0;f<=511;f++)
printf("%c,",buffer[f]);
//prints address of buffer to see if match the pointer
printf("\n\r");
printf("\n\rBuffer address = %ld",&(buffer[0]));
printf("\n\rptra points to = %ld",ptra);
printf("\n\r");
//call the write block function from driver
if(mmc_write_block(address, size, &buffer[0])==0)
printf("\n\rwrite ok \n\r");
else
printf("\n\rwrite fault \n\r");
//clear the buffer
for(f=0;f<=511;f++)
buffer[f]=0;
printf("\n\r");
printf("\n\r");
//call the read block function from driver
if(mmc_read_block(address, size, &buffer[0])==0)
printf("\n\rread ok\n\r");
else
printf("\n\rread fault");
//print the buffer to see if is the same as PIC send
printf("\n\r What the PIC receive must be the same as the buffer:\n\r");
for(f=0;f<=511;f++)
size=0;
address+=512;
printf("\n\rStart again\n\r");
#int_rda
void trata_rda()
buffer[size]=getc();
size++;
////////////////////// Driver for Multimedia Card ///////////////////////
//// mmc_init() - Reset and Initialize the MMC. Returns zero if OK ////
//// mmc_modify_byte(address, val) - Modify the byte at address to ////
//// change it's value to val. Will read/write the ////
//// entire 512 byte block but only change this ////
//// specific byte. Returns zero if OK. ////
//// mmc_modify_block(address, size, *ptr) - Modifies the bytes ////
//// to change their value to whats stored at *ptr. ////
//// Will read/write the entire 512 byte block(s) but ////
//// only change the values defined by ptr and size. ////
//// Returns zero if OK. ////
//// mmc_write_block(address, size, *ptr) - Writes a 512 byte ////
//// block to the MMC. If size is less than 512 then ////
//// unspecified data will be written as 0. Returns ////
//// zero if OK. ////
//// mmc_read_byte(address,*ptr) - Reads the byte specified at ////
//// address. Result is saved to ptr. Returns zero ////
//// if OK. ////
//// mmc_read_block(address, size, *ptr) - Reads the bytes ////
//// specified at address. Result is saved to ptr. ////
//// NOTE: You might get an address error if you try ////
//// to read over a page size. For example, trying ////
//// to read a block size of 512 starting at address ////
//// 0x100 may cause an error because you are reading ////
//// two blocks. ////
//// mmc_erase(address, blocks) - Erases the block specified at ////
//// address. Will erase the entire 512 byte block. ////
//// If you wish to erase more blocks after specified ////
//// block use the blocks parameter to specifiy how ////
//// many extra blocks to erase. Returns zero if OK. ////
//// ~~~~~~~ MULTI-READ FUNCTIONS ~~~~~~~~ ////
//// mmc_read_enable(address, size) - Start multi-reads at ////
//// specified address. Size is the size of each ////
//// individual read. Returns zero if OK. ////
//// mmc_read_mult_block(*ptr) - Reads data from the MMC, and saves ////
//// to ptr. The number of bytes read is defined ////
//// by mmc_read_enable(). You must call ////
//// mmc_read_enable() before you can call this. ////
//// mmc_read_disable(void) - Stop a multi-read. ////
//// MAY BE BROKEN. ////
//// (C) Copyright 1996,2001 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
/////*** USER CONFIG ***/////
//SanDisk’s MultiMediaCards clock data in on the rising edge and out on the falling edge.
#ifndef MMC_CLK
#define MMC_CLK PIN_B1
#endif
#ifndef MMC_DI
#define MMC_DI PIN_B0
#endif
#ifndef MMC_DO
#define MMC_DO PIN_B3
#endif
#ifndef MMC_CS
#define MMC_CS PIN_B2
#endif
enum MMC_EC {
MMC_EC_OK = 0,
MMC_EC_NOT_IDLE = 1, //after reset command, device wasn't in idle state
MMC_EC_NOT_INIT = 2, //after init command, device had an error
MMC_EC_NO_CRC = 3, //CRC wouldn't turn off
MMC_EC_SET_READ_BLOCKSIZE_FAIL = 4, //gave us an error during set blocksize
MMC_EC_SET_WRITE_BLOCKSIZE_FAIL = 5, //gave us an error during set blocksize
MMC_EC_SET_MULTI_BLOCKSIZE_FAIL = 6, //gave us an error during set blocksize
MMC_EC_SET_WRITE_ADDRESS_FAIL = 7, //gave us an error when we told it we want to write block
MMC_EC_BLOCK_NOT_WRITTEN = 8, //after sending block, it gave us this response
MMC_EC_SET_READ_ADDRESS_FAIL = 9, //gave us an error when we told it we wanted to read block
MMC_EC_ERASE_SECTOR_START_FAIL = 10, //mmc gave us an error when we set the start sector for erase
MMC_EC_ERASE_SECTOR_END_FAIL = 11, //mmc gave us an error when we set the end sector for erase
MMC_EC_ERASE_SECTORS_FAIL = 12, //mmc gave us an error when we told it to erase tagged sectors
MMC_EC_BAD_STATE = 13, //we cant start/continue a multi transfer because we didn't start/finish the last one
MMC_EC_START_MULTI_READ_FAIL = 14, //mmc gave us an error when we started a multi-read
MMC_EC_READ_NEXT_BLOCK_FAIL = 15, //mmc gave us an error when started to read the next block (in multi-read)
MMC_EC_STOP_TRANSMISSION_FAIL = 16, //mmc gave us an error when tried to stup a multi read/write transmission
MMC_EC_WRITE_ALWAYS_BUSY = 17 //after a block write, we waited longer than timeout period for busy signal to end
//#define MMC_DEBUG PRINTF //uncomment this line to print out debug messages
#define MMC_DEBUG(a,b,c,d,e,f,g,h,i,j,k) //uncomment this line to not print out debug messages
/////*** END USER CONFIG ***/////
//if you want to slow down the speed of the MMC clock, define delay_clk to a delay_xx() routine
//#define mmc_delay_clk() delay_us(1)
#define MMC_BLOCK_SIZE 512
int16 mmc_last_result=0;
// FUNCTIONS
//public functions
MMC_EC mmc_init();
MMC_EC mmc_modify_byte(int32 address, int8 val);
MMC_EC mmc_modify_block(int32 address, int16 block_size, int *ptr);
MMC_EC mmc_write_block(int32 address, int16 block_size, int *ptr);
#define mmc_read_byte(a,p) mmc_read_block(a,1,p)
MMC_EC mmc_read_block(int32 address,int16 block_size, int *ptr);
MMC_EC mmc_erase(int32 address, int32 sectors);
MMC_EC mmc_read_enable(int32 address, int16 block_size);
MMC_EC mmc_read_mult_block(int *ptr);
MMC_EC mmc_read_disable(void);
/* NOT TESTED ROUTINES
short mmc_write_enable(int32 address, int16 block_size);
short mmc_write_mult_block(int *ptr);
void mmc_write_disable();
void mmc_read_csd(int *ptr);
void mmc_write_csd(int *ptr);
//private functions
int16 mmc_send_cmd(int cmd, int32 arg, int mode);
void mmc_send_data(int d_byte);
int mmc_read_data();
void mmc_select(void);
void mmc_deselect(void);
int1 mmc_wait_for_not_busy(int16 to); //to in 8 clocks
int1 mmc_receive_data(int8 *ptr, int16 size);
// GLOBALS
enum {MMC_STARTUP_STATE=0, MMC_STANDBY_STATE=1, MMC_WRITE_STATE=2,
MMC_READ_STATE=3, MMC_ERASE_STATE=4} mmc_state=MMC_STARTUP_STATE;
//holds the current block size of our multi-read or multi-write routines
int16 mmc_blk_size;
#define MMC_CMD_GO_IDLE_STATE 0
#define MMC_CMD_SEND_OP_COND 1
#define MMC_CMD_STOP_TRANSMISSION 12
#define MMC_CMD_SET_BLOCKLEN 16
#define MMC_CMD_READ_SINGLE_BLOCK 17
#define MMC_CMD_READ_MULTITPLE_BLOCK 18
#define MMC_CMD_WRITE_BLOCK 24
#define MMC_CMD_TAG_SECTOR_START 32
#define MMC_CMD_TAG_SECTOR_END 33
#define MMC_CMD_ERASE 38
#define MMC_CMD_CRC_ON_OFF 59
//************************* Public Functions ****************************//
// mmc_init() Initializes the unit.
// Paramaters: <none>
// Returns: 0 if initiated correctly
// Non-zero if initiation failed
// Special Info: This should be called immediately to initialize
// the multi media card.
MMC_EC mmc_init(void) {
int16 result;
int8 to=50;
mmc_state = MMC_STARTUP_STATE;
output_high(MMC_CS);
output_high(MMC_DO); // set pin levels
output_high(MMC_CLK);
// output_low(MMC_CLK);
output_float(MMC_DI);
delay_ms(15);
do {
mmc_select();
result=mmc_send_cmd(MMC_CMD_GO_IDLE_STATE,0,1);
mmc_deselect();
if (result==1)
break;
else {
delay_ms(10);
to--;
} while (to);
if (result!=1) {
MMC_DEBUG(" ERR: after reset, device isn't idle");
return(MMC_EC_NOT_IDLE);
to=50;
do {
mmc_select();
result = mmc_send_cmd(MMC_CMD_SEND_OP_COND,0,1); // puts card into ready state
mmc_deselect();
if (result && (result!=1)) {
MMC_DEBUG(" ERR: after init we got a funky error %LX", result);
return(MMC_EC_NOT_INIT);
else if (result==1) {
to--;
delay_ms(1);
else
break;
} while (to); // loop until not busy
MMC_DEBUG(" init cmd returns: %X\n\r",result);
mmc_select();
result=mmc_send_cmd(MMC_CMD_CRC_ON_OFF,0,1);
mmc_deselect();
if (result) {
MMC_DEBUG(" ERR: CRC didn't turn off");
return(MMC_EC_NO_CRC);
mmc_state = MMC_STANDBY_STATE; // set current state
return(MMC_EC_OK);
// mmc_modify_block()
// Writes a block to the MMC. This routine will read the
// entire 512 byte block first, and then make modifications
// to that in RAM and save it back to MMC. Therefore, this
// is the function to use if you want to write data that is
// less than the size of the block (512 bytes)
// Paramaters: address: address to write to
// ptr: data byte to write
// size: number of bytes to write
// Returns: TRUE if write worked correctly
// FALSE if failed
MMC_EC mmc_modify_block(int32 address, int16 size, int *ptr) {
int8 mmc_buffer[MMC_BLOCK_SIZE];
int val;
int16 i;
int32 block_start;
int16 num;
MMC_EC res;
val = 0;
block_start=address & 0xFFFFFE00;
i=address-block_start;
while(size) {
res=mmc_read_block(block_start, MMC_BLOCK_SIZE, mmc_buffer);
if (res) {
MMC_DEBUG(" cannot read 512 byte block. nothing written! \n\r");
return(res);
MMC_DEBUG(" read 512\r\n");
if ((size+i)>MMC_BLOCK_SIZE) {num=MMC_BLOCK_SIZE-i;} else {num=size;}
memcpy(&mmc_buffer[i],ptr,num);
res=mmc_write_block(block_start, MMC_BLOCK_SIZE, mmc_buffer);
if (res) {
MMC_DEBUG(" cannot write MMC_BLOCK_SIZE byte block\r\n");
return(res);
MMC_DEBUG(" 512 written\r\n");
ptr+=num;
block_start+=MMC_BLOCK_SIZE;
size-=num;
i=0;
return(MMC_EC_OK);
MMC_EC mmc_modify_byte(int32 address, int8 val) {
return(mmc_modify_block(address,1,&val));
// mmc_write_block()
// Writes a block to the MMC. The address must start at the
// beginning of a block (every 512 bytes).
// size: number of bytes to write from RAM
// FALSE if failed
// Notes: If address does not start at a block boundry, the MMC will
// give you an error.
// If you have a size less than 512 the rest of the data will
// be saved as 0.
MMC_EC mmc_write_block(int32 address, int16 size, int *ptr) {
int16 j;
int8 val;
int8 res;
mmc_select();
res=mmc_send_cmd(MMC_CMD_SET_BLOCKLEN, MMC_BLOCK_SIZE, 1);
mmc_deselect();
if (res)
MMC_DEBUG(" set block size failed\n\r");
return(MMC_EC_SET_WRITE_BLOCKSIZE_FAIL);
mmc_select();
res=mmc_send_cmd(MMC_CMD_WRITE_BLOCK,address,1); // command to write byte at address
if (res)
MMC_DEBUG(" write byte failed. Nothing written!\n\r");
mmc_deselect();
return(MMC_EC_SET_WRITE_ADDRESS_FAIL);
mmc_send_data(0xFF); // send nothing for 8 bits
mmc_send_data(0xFE); // send start bit
for(j=0; j<MMC_BLOCK_SIZE; j++)
if (size) {
val=*ptr;
ptr++;
size--;
else {
val=0;
mmc_send_data(val); // writes the byte
mmc_send_data(0xFF); //crc
val = mmc_read_data() & 0x1F;
MMC_DEBUG(" write data returned: %X\n\r",val);
if (!mmc_wait_for_not_busy(1000)) {
MMC_DEBUG(" ERR: mmc spi is busy\r\n");
return(MMC_EC_WRITE_ALWAYS_BUSY);
mmc_deselect();
if(val!=5) // if not stored correctly
MMC_DEBUG(" data not stored\n\r");
return(MMC_EC_BLOCK_NOT_WRITTEN);
MMC_DEBUG(" data was stored\n\r");
return(MMC_EC_OK);
// mmc_read_block()
// Reads a single block to the mmc
// Paramaters: address: address to read from
// block_size: number of bytes in block
// ptr: value to store bytes
// Returns: TRUE if valid data
// FALSE if not valid data
MMC_EC mmc_read_block(int32 address, int16 block_size, int *ptr) {
int16 i;
int16 result;
mmc_select();
result=mmc_send_cmd(MMC_CMD_SET_BLOCKLEN,block_size,1);
mmc_deselect();
if (result) { // sets the block size
MMC_DEBUG(" ERR: couldn't set read block size\r\n");
return(MMC_EC_SET_READ_BLOCKSIZE_FAIL);
mmc_select();
result=mmc_send_cmd(MMC_CMD_READ_SINGLE_BLOCK,address,1);
if(result) // command to read byte at address
mmc_deselect();
MMC_DEBUG(" ERR: couldnt set read address\r\n");
return(MMC_EC_SET_READ_ADDRESS_FAIL);
mmc_receive_data(ptr,block_size);
mmc_deselect();
return(MMC_EC_OK);
// mmc_erase()
// Erases sectors on the mmc
// Paramaters: address: sector number
// sectors: number of sectors to erase
// Returns: <none>
// Calls: send_cmd
// Special Info: All data will be lost in the sectors!
MMC_EC mmc_erase(int32 address, int32 sectors) {
int32 sector_start;
int32 sector_end;
int8 res;
if (sectors) {
sector_start=address/MMC_BLOCK_SIZE;
sector_end=sector_start + sectors - 1;
mmc_select();
res=mmc_send_cmd(MMC_CMD_TAG_SECTOR_START, sector_start, 1);
mmc_deselect();
if (res) {return(MMC_EC_ERASE_SECTOR_START_FAIL);}
mmc_select();
res=mmc_send_cmd(MMC_CMD_TAG_SECTOR_END, sector_end, 1);
mmc_deselect();
if (res) {return(MMC_EC_ERASE_SECTOR_END_FAIL);}
mmc_select();
res=mmc_send_cmd(MMC_CMD_ERASE,0,1);
mmc_deselect();
if (res) {return(MMC_EC_ERASE_SECTORS_FAIL);}
return(MMC_EC_OK);
// Enables streamming read mode for the mmc
// Paramaters: address: start address
// block_size: size of one block
// Returns: TRUE if enabled
// FALSE if error
// Calls: send_cmd
// read_cmd
// Special Info: Use this to enable multiple reads, starting at
// the address passed in.
// NOT TESTED
MMC_EC mmc_read_enable(int32 address, int16 block_size) {
int16 ret;
if(mmc_state!= MMC_STANDBY_STATE) { // make sure not currently in other state
MMC_DEBUG(" ERR: not in good state for multi-read\r\n");
return(MMC_EC_BAD_STATE);
mmc_state = MMC_READ_STATE; // set to correct state
mmc_blk_size = block_size;
mmc_select();
ret=mmc_send_cmd(MMC_CMD_SET_BLOCKLEN,block_size,1);
mmc_deselect();
if(ret) { // sets the block size
MMC_DEBUG(" ERR: multi read didnt set block\r\n");
return(MMC_EC_SET_MULTI_BLOCKSIZE_FAIL);
mmc_select();
ret=mmc_send_cmd(MMC_CMD_READ_MULTITPLE_BLOCK,address,1);
if(ret) { // sets the address to read from
MMC_DEBUG(" ERR: doesnt like multi read\r\n");
mmc_deselect();
return(MMC_EC_START_MULTI_READ_FAIL);
return(MMC_EC_OK);
// mmc_read_mult_block()
// Reads a data byte from the mmc
// FALSE if error
// Calls: read_data
// Special Info: Use this after enabling multiple reads. This
// reads only a single byte. Call multiple times
// to read multiple bytes.
// NOT TESTED
MMC_EC mmc_read_mult_block(int *ptr) {
if(mmc_state != MMC_READ_STATE) { // check for correct state
MMC_DEBUG(" err: bad state\r\n");
if (!mmc_receive_data(ptr,mmc_blk_size)) {
MMC_DEBUG(" err: cant read multi block\r\n");
mmc_deselect();
return(MMC_EC_READ_NEXT_BLOCK_FAIL);
return(MMC_EC_OK);
// mmc_read_disable()
// Disables multiple reads to the mmc
// Returns: <none>
// Calls: send_cmd
// Special Info: Use this when done with multiple reads. This
// disables reading, and will cause an error if the
// user tries another read.
// NOT TESTED
#define mmc_read_disable() mmc_stop_transmission()
MMC_EC mmc_stop_transmission(void) {
int8 res;
res=mmc_send_cmd(MMC_CMD_STOP_TRANSMISSION,0,1);
mmc_deselect();
// if (res) {
// MMC_DEBUG(" err: couldnt stop transmission\r\n");
// return(MMC_EC_STOP_TRANSMISSION_FAIL);
return(MMC_EC_OK);
// mmc_write_enable()
// Enables streamming write mode for the mmc
// FALSE if error
// Calls: send_cmd
// read_cmd
// Special Info: Use this to enable multiple writes, starting at
// NOT TESTED
/* NOT TESTED
short mmc_write_enable(int32 address, int16 block_size) {
if(mmc_state!= STANDBY_STATE) // make sure not currently in other state
return FALSE;
mmc_state = WRITE_STATE; // set to correct state
if (mmc_send_cmd(16,block_size,1)) // sets the block size
return false;
if(mmc_send_cmd(25,address,1)) // sets the address to write to
return false;
return TRUE;
// mmc_write_mult_block()
// Writes a data byte to the mmc
// Paramaters: The byte to write
// FALSE if error
// Calls: send_data
// Special Info: Use this after enabling multiple writes. This
// writes only a single byte. Call multiple times
// to write multiple bytes.
// NOT TESTED
/* NOT TESTED
short mmc_write_mult_block(int *ptr) {
int i;
if(mmc_state != WRITE_STATE) // check for correct state
return FALSE;
mmc_send_data(0xFD);
for(i=0; i<blk_size; i++)
mmc_send_data(*ptr++); // write the data byte
mmc_send_data(0); // blank crc
mmc_send_data(0);
if(read_data_response()==5) // if not stored correctly
return TRUE;
else
return FALSE;
// mmc_write_disable()
// Disables multiple writes to the mmc
// Returns: <none>
// Calls: send_cmd
// Special Info: Use this when done with multiple writes. This
// disables writing, and will cause an error if the
// user tries another write.
// NOT TESTED
/* NOT TESTED
void mmc_write_disable() {
mmc_state = STANDBY_STATE;
mmc_send_cmd(12,0,1); // stops multiple block writes
/* NOT TESTED
void read_csd(int *ptr) {
int i;
mmc_select();
mmc_send_cmd(9,0,1);
mmc_read_data();
for(i=0;i<16;i++)
*ptr++ = mmc_read_data();
mmc_read_data();
mmc_read_data();
mmc_deselect();
/* NOT TESTED
void write_csd(int *ptr) {
int i;
mmc_select();
mmc_send_cmd(27,0,1);
for(i=0;i<16;i++)
mmc_send_data(0);
mmc_send_data(0);
i= mmc_read_data();
MMC_DEBUG(" write csd gets %X\n\r", i);
mmc_deselect();
//************************ Private Functions ****************************//
// mmc_send_cmd()
// sends a command to the mmc, then gets the response
// Paramaters: cmd: command number
// arg: 32 bit argument
// mode: what kind of response should we get?
// if mode==1, Format R1 (one byte response)
// if mode==2, Format R2 (two byte response)
// if mode==3, Format R3 (five byte response)
// if mode==0 then don't get a response
// Returns: Error code given by MMC (R1, R2 or R3 format)
// 0 if no error.
int16 mmc_send_cmd(int cmd, int32 arg, int8 mode) {
int i;
int out[6];
int8 to=50;
int8 bits;
if (!mmc_wait_for_not_busy(50)) {
mmc_last_result=0xFFFF;
return(mmc_last_result);
out[0] = cmd | 0x40; // bits 47 to 40
out[4] = make8(arg,0); // bits 15 to 8
out[3] = make8(arg,1); // bits 23 to 16
out[2] = make8(arg,2); // bits 31 to 24
out[1] = make8(arg,3); // bits 39 to 32
if (cmd==0) {
out[5] = 0x95;
else {
out[5] = 0xFF; //ignore the CRC
for (i=0;i<6;i++)
mmc_send_data(out[i]);
MMC_DEBUG("\n\r sent cmd %U, arg %LU\n\r", cmd, arg);
if (!mode) {return(0);}
if(mode == 1)
bits = 8;
else if(mode == 2)
bits = 16;
else if(mode == 3)
bits = 48;
else
bits = 0;
for(i=0;i<5;i++)
out[i] = 0;
i=0;
do {
i++;
mmc_delay_clk();
mmc_delay_clk();
} while((input(MMC_DI))&&(to--));
if (input(MMC_DI)) {
MMC_DEBUG(" err: no start bit waiting for response\r\n");
mmc_last_result=0xFFFE;
shift_left(out,5,input(MMC_DI)); // input start bit = '0'
mmc_delay_clk();
for(i=0; i<(bits-1); i++)
mmc_delay_clk();
mmc_delay_clk();
MMC_DEBUG(" i=%U\r\n",i);
MMC_DEBUG(" cmd data in = %x", out[0]);
do {
out[0]=mmc_read_data();
} while ((bit_test(out[0],7))&&(to--));
if (mode==2) {
out[1]=mmc_read_data();
if (mode==3) {
out[2]=mmc_read_data();
out[3]=mmc_read_data();
out[4]=mmc_read_data();
if(mode == 1) {
MMC_DEBUG("\r\n");
mmc_last_result=out[0];
else if(mode == 2) {
MMC_DEBUG(", %x\r\n",out[1]);
mmc_last_result=make16(out[1],out[0]); //not tested
else if(mode == 3) {
MMC_DEBUG("\r\n");
mmc_last_result=out[0]; //not tested
void mmc_spi_exchange(int8 out, int8 *in) {
int8 i;
for (i=0;i<8;i++) {
output_bit(MMC_DO, shift_left(&out,1,0));
mmc_delay_clk();
mmc_delay_clk();
shift_left(in,1,input(MMC_DI));
mmc_delay_clk();
mmc_delay_clk();
// mmc_send_data()
// sends a data byte to the mmc
// Paramaters: the byte sent
// Returns: nothing
// Special Info: You can use this function to generate 8 clocks with no data.
// Use a paramater of 0xFF to do this.
void mmc_send_data(int8 data) {
int8 null;
mmc_spi_exchange(data,&null);
// mmc_read_data()
// software SPI bit banging to read from MMC
// Paramaters: none
// Returns: data byte read
// Special Info: used for read data respose to write
int8 mmc_read_data(void) {
int8 ret;
mmc_spi_exchange(0xFF,&ret);
return(ret);
// mmc_select()
// Sets the MMC CS so the MMC is selected
// Paramaters: none
// Returns: none
// Special Info: Must be called before a mmc_send_cmd()
void mmc_select(void) {
#ifdef MMC_UNIT_ID
int i;
int1 old_gie;
// If program uses interrupts disable them
// during this function
#if defined(__PCM__)
old_gie=bit_test(*0x0b,7);
bit_clear(*0x0b,7);
#elif defined(__PCH__)
old_gie=bit_test(*0xFF2,7);
bit_clear(*0xFF2,7);
#endif
do {
do {
while(!input(MMC_CS));
delay_us(10);
} while(!input(MMC_CS));
output_low(MMC_CS);
for(i=1;i<=MMC_UNIT_ID;i++)
delay_us(25);
output_float(MMC_CS);
delay_us(5);
output_low(MMC_CS);
for(i=1;i<=(8-MMC_UNIT_ID);i++)
delay_us(25);
if (old_gie) {
bit_set(*0x0b,7);
bit_set(*0xFF2,7);
#endif
#else
output_low(MMC_CS);
#endif
// mmc_deselect()
// Sets the MMC CS so the MMC is no longer selected.
// Also generates 8 blank clocks which the MMC uses to
// finish the CMD.
// Paramaters: none
// Returns: none
// Special Info: Most of the time must be called after a mmc_send_cmd(), after
// the cmd has processed.
void mmc_deselect(void) {
mmc_send_data(0xFF); //send 8 clocks for MMC to get ready for next command
// mmc_wait_for_not_busy()
// Waits for the DI line to indicicate that the MMC is no longer
// busy.
// Paramaters: Number of 8 clocks we should wait until line goes high.
// Returns: TRUE if not busy, FALSE if busy.
int1 mmc_wait_for_not_busy(int16 to) {
int8 i;
do {
for (i=0;i<8;i++) {
mmc_delay_clk();
mmc_delay_clk();
} while((!input(MMC_DI))&&(to--));
if (input(MMC_DI))
return(TRUE);
return(FALSE);
int1 mmc_receive_data(int8 *ptr, int16 size) {
int8 to=50;
int16 i;
do {
if (mmc_read_data() == 0xFE)
break;
else {
to--;
delay_ms(1);
if (!to) {
MMC_DEBUG(" ERR: didnt get repsone when reading\r\n");
return(FALSE);
} while (to);
for(i=0; i< size; i++) {
*ptr = mmc_read_data(); // reads each byte
ptr++;
mmc_read_data();
mmc_read_data();
return(TRUE);
