Gerelectronic
Newbie
Hello everybody.
I am working on my personal electronics project.
I want to create a program that is able to communicate the pic18f452 with an LCD display, an SD card and a GPS module.
I would like the program to succeed in the following operations:
- 1) Read the information from the GPS via Uart and send it to the LCD display.
- 2) When it has sent the first string coming from the GPS module to the LCD display, the pic sends this information to the SD card so that if it is connected to a computer, the data coming from the GPS in text format (FAT 16) can be read .
- 3) The cycle starts again.
I managed to accomplish point number 1 but when I try to initialize the SD card the pic stops receiving information from the gps module.
Could someone help me to carry out point 2?
The program that I have managed to carry out so far is the following:
If you find it useful, I also attach the photo of the circuit on Proteus.
Thanks a lot to everyone.
Sorry for the bad English.
Long live electronics!
C:
//Memory Card Chip Select Connection
sfr sbit Mmc_Chip_Select at RC2_bit;
sfr sbit Mmc_Chip_Select_Direction at TRISC2_bit;
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
char txt5[] = "GPS with PIC877A";
char txt6[] = "F.M.S.";
// "$xxxxx,xxxxxxxxx,xxxx.xxx,x,xxxxx.xxx,x,x,xx,x.x,xxx.x,x,xx.x,x,,*xx"; GPGGA
int i = 0;
int received = 0;
char DataType[] = "GPXXX";
char NMEA[] = "$xxxxx,xxxxxx.xx,x,xxxx.xx,x,xxxxx,x,x.x,x.x,xxxxxx,x.x,x*xx";
char receive;
unsigned char filename[] = "Temp.TXT";
unsigned char error;
void main()
while(1)
TRISD = 0x00;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,1,txt5); // Write text in first row
Lcd_Out(2,6,txt6); //displays txt5
Delay_ms(1000); //displays txt6
Lcd_Cmd(_LCD_CLEAR); // Clear display
Delay_ms(250);
UART1_Init(9600); // Initialize UART for GPS board connectivity
SPI1_Init();
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV64, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
Delay_us(10);
Delay_mS(100);
while(1)
if (UART1_Data_Ready() == 1)
receive = UART1_Read();
if (receive == '$') // Check if sentence begins.
received = 0;
do
UART1_Read_Text(DataType, ",", 10); // Capture GPXXX word
received = 1;
while(received == 0);
// If it is GPRMC Data, then acquire it.
if ((DataType[2] == 'R') && (DataType[3] == 'M') && (DataType[4] == 'C'))
received = 0;
do
UART1_Read_Text(NMEA, "*", 100); // Stop at *XX checksum data
received = 1;
// Latitude
LCD_Out(1,1, "La:");
LCD_Chr(1, 5, NMEA[13]);
LCD_Chr(1, 6, NMEA[14]);
LCD_Chr(1, 7, 223);
LCD_Chr(1, 8, NMEA[15]);
LCD_Chr(1, 9, NMEA[16]);
LCD_Chr(1, 10, NMEA[17]);
LCD_Chr(1, 11, NMEA[18]);
LCD_Chr(1, 12, NMEA[19]);
LCD_Chr(1, 13, NMEA[20]);
LCD_Chr(1, 14, NMEA[21]);
LCD_Chr(1, 16, NMEA[23]);
// Longitude
LCD_Out(2,1, "Lo:");
LCD_Chr(2, 5, NMEA[25]);
LCD_Chr(2, 6, NMEA[26]);
LCD_Chr(2, 7, 223);
LCD_Chr(2, 8, NMEA[27]);
LCD_Chr(2, 9, NMEA[28]);
LCD_Chr(2, 10, NMEA[29]);
LCD_Chr(2, 11, NMEA[30]);
LCD_Chr(2, 12, NMEA[31]);
LCD_Chr(2, 13, NMEA[32]);
LCD_Chr(2, 14, NMEA[33]);
LCD_Chr(2, 15, NMEA[34]);
LCD_Chr(2, 16, NMEA[36]);
Delay_Ms(1000);
//DATA
Lcd_Out(1,1,"Data:");
LCD_Chr(1, 7, NMEA[50]);
LCD_Chr(1, 8, NMEA[51]);
LCD_Chr(1, 9, '/');
LCD_Chr(1, 10, NMEA[52]);
LCD_Chr(1, 11, NMEA[53]);
LCD_Chr(1, 12, '/');
LCD_Chr(1, 13, NMEA[54]);
LCD_Chr(1, 14, NMEA[55]);
//ORA
Lcd_Out(2,1,"Ora:");
LCD_Chr(2, 6, NMEA[0]);
LCD_Chr(2, 7, NMEA[1]);
LCD_Chr(2, 8, ':');
LCD_Chr(2, 9, NMEA[2]);
LCD_Chr(2, 10, NMEA[3]);
LCD_Chr(2, 11, ':');
LCD_Chr(2, 12, NMEA[4]);
LCD_Chr(2, 13, NMEA[5]);
Delay_Ms(1000);
receive = "x";
