boylesg
- Joined
- Jul 15, 2012
- Messages
- 1,023
- Helped
- 5
- Reputation
- 10
- Reaction score
- 6
- Trophy points
- 1,318
- Location
- Epping, Victoria, Australia
- Activity points
- 11,697
Would passing the supply through one of these before it enters the input pin of the LM317 effect the performance of the LM317 in any way?
I have implemented my high current adjustable voltage reg with a protective diode on the input but it appears that it is causing the voltage from the reg to waver a bit around my target voltage.
Shorting the diode appears to improve matters.
I was trying to test this with alligator clip across the blobs of solder on the back - electrical contact may not have been ideal with this however.
