Schematics of usb to serial and serial to usb circuits
electronicavr
Junior Member level 3
hello
:D
i need a circuit shematic of usb to serial(rs-233)or serial to usb
i need this circuit for pc cable of logo(siemens)
very thank
:D
Re: usb to serial
Maybe you could use the CP2101 of Silicon Laboratories.
Here is the datasheet. It have the aplication circuit, it's realy easy to use.
Regards.
usb to serial
you can use FT2232C to implement it
usb to serial
FT232R is a very good one. No crystal required just like the CP2101. More expensive though.
The CP210x is very good, but for DIY fans the package is hard to handle.
Re: usb to serial
Hi
U can use FT232BM usb to rs232 transceiver and max3221 and proceed with design......
Re: usb to serial
Regards.
I am also using cp2101 to convert USB to Serial.....
i have designed the PCB according to the circuit.......
But now i want to kw whether It(CP2101) will need a progarm to run or will do it do it directly...
if it needs a program please send me
usb to serial
CP210x default is ready to go.
However you do be able to change some of the staff. But if you don't, it is fine.
