nawaz.mjcet
Newbie level 6
HI all,
while doing formality i'm facing problem in schematics as follows:
there is a flip flop(in schematics) whose inputs and outputs are
AC(asynchronous clear )
SL(synchronous load)
SD(synchronous data)
CLK(clock)
Q(D output)
QN(negation of output )
but the same flip flop in netlist have input and output pins as follows:
D(data)
CLK(clock)
RST(reset)
Q(output)
QN (negation of output)
the SL pin in schematics flop is missing in netlist flop,why is the tools showing a pin in schematics which is not in netlist and for the existing pins also the names are not same....???...please kindly reply....
Thanks in advance,
Regards,
-Nawaz.
CLK(clock)
Q(D output)
D(data)
CLK(clock)
RST(reset)
Q(output)
Thanks in advance,
Regards,
-Nawaz.
