Schematic of a digital compass
asic1984
Full Member level 5
Full Member level 5
hi all
where can i find the schematic of digital compass
thanks for help
fluxgate compass schematic
Search phillips site. They have an IC for compass, i believe that the part number is KMZ51 . But itsn't easy to build one, you need tho interface the Ic with a µC, just buy one already assembled for use. See at **broken link removed**.
And they have many others modules for robotics.
digital compass schematic
Search also the Circuit Celler Magazine. I think there is an artical about that. It's some issues back in this year.
homemade digital compass
Compass schematics seem hard to find. Elektor have a simple project for a Lego RCX in the May 2002 issue - I've attached it here. It uses a Pewatron type 6945 compass sensor.
You may find more information in the manufactures datasheets here:
http://www.pewatron.com/GB/default.htm
Cheers,
FoxyRick.
kmz51 compass
I have been searching for information about this aslo. My result is that the sensor to use is the KMZ51 from philips (got 3 of them already) There are also simular sensors and a lot of theoretical info from Honywell but they are much more expensive and harder to buy.
As I understand there are two ways of bulding a compas, the simpel way with two sensor and always keep the unit in upright position, the oter variant is using 3 magnetics sensors and do a tilt compensation with a two axis gyro of some sort. The last solution would be rather complicated, and where to get gyros thet dont cost 100s of $?
Some links with information i found after much searching...
KMZ51 for lego robots, with simple schematics:
https://www.convict.lu/Jeunes/CompassSensor.htm
Possible source of gyros but how to buy?
https://www.vti.fi/en/index.html
Some schematics, but nothing compleat.
https://magnetometer.captain.at/
At las I also attache two schematics for KMZ51 that I found on the net somwhere, cant remember where.
If someone has more info or hands on experience, please comment...
regards Me
digital electronic compass wiki
Some of the GPS recievers have this integrated with the handheld module.
B R M
homemade fluxgate compass
Hi aslm
How did you get them ?... samples ?
kmz51 schematic
KMZ51 can be order from ELFA (www.elfa.se) witch is a electronics supplier of northern europe. A bit expensive tho, 7,34 euro...
I dont know to what contrys the ship to (only tried sweden) but I know the now have resellers in several european contrys.
re Me
digital compass circuit
hi,
u can find useful data at
MODERATOR ACTION: link provided by you is not working so removed
3d digital compass
any can write simple code for kmz51 ????
i can't drive copens coil and filip coil
can you help me ?????
digital compass datasheet
hello
Microchip has a application note
AN996, Designing a Digital Compass Using the PIC18F2520
h**p://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en024198
digital compass schematics
Electronic Compass Design
+digital compass +schematic
can anyone provide a pdf file for this circuitrywhich covers all data?
in above file datasheet is not included from here i can got that
buy kmz51 ic
Calibration is another tough issue i think.What do you think about this?
digital compass europe suppliers -china
Use a circular fluxgate or two (may be three) orthogonal straight fluxgates.
You will get 2D/3D vectors for the magnetic field.
Search internet for fluxgate compasses. Fluxgate sensors can be home brewed.
I remember Practical Electronics had one design of home made Fluxgate compass in '70 or '80s.
Also, check
http//geotech.thunting.com/pages/mag/projects/fmx1/fmx1.pdf
http//geotech.thunting.com/pages/mag/projects/cheeseman/cheeseman_mag1_150.pdf
http//geotech.thunting.com/pages/mag/projects/cheeseman/cheeseman_mag2_150.pdf
http//en.wikipedia.org/wiki/Fluxgate_compass
http//crocus.physics.mcmaster.ca/Magnetometer/TW/
http//www.freepatentsonline.com/5165269.html
Added after 2 minutes:
And also check the related patents at
There may be more patents, you can check on USPTO and espacenet.
