Schematic for repeater PMR on ISD25
gres
Full Member level 4
Full Member level 4
Repeater PMR on ISD25
It's a simple but very useful device for radio fans.
Repeater base on ISD2560/75 or 90 chip. Lower record time means that sound quality is better, so the best choice would be 2560. System is controlled by PIC. To input signal goes from radio , is recording and playing, signals shorter ther 1s are ignore.
Elements description:
0,1 mikrofarad 7
22 pF 2 ceramic units
10 mikrofarads
Voltage stabilizer 7805 in TO-92 casing
1N4001 diode
1N4148 diode
10k 3 units
22k
2,2k
100k
330k
4,7k 2 units
1k
1,5 Mega ohm
330 ohm
100 ohm
260 - 300 ohm ( you need to take something from this range
Line potentiometer 100k ( it regulate recording signal level e.g. repeater will record only clear sound, or only noise )
Logarithmic potentiometer 10k ( modulate regulation while sending)
Quartz 4 MHz
Green led
Red led
Base with 28 legs ISD 2560/75/90
Base with 18 legs PIC16F84
PIC16F84
ISD2560/2575 or 2590
BC 549B 2 units
Most expensive is ISD system , rest is very cheap.
If after complete system can't start sending, you need to exchange R7 to 2,4k
System should be powered from 6 to 12V
After start green led should blink twice.
When repeater is recording, green diode is on, when playing red is on.
Elements at the board:
Here you can find software for recording, unfortunatly only 60 seconds. 75 and 90 i don't have but after had installed chip with longer recording time will stop after 60 sec.
Board is ready to print.
"Zworki" means jumpers diagram
Diagram
All of this you can find at[url[http://www.elektroda.pl/rtvforum/topic1495036.html[/url]
