yefj
Advanced Member level 5
Hello,when working on scattering problems you want to filter out the scattered field.
but the simulation excitation source is keep sending the excitation field signal.
So if i same the field cut.
i get a 2D array of sample of complex number which represent the scattered and incident field together.
Is there a way to do some furier transform on the samples to find what field component are present ?
Thanks.
Thanks.
