ichibindigi
Newbie level 5
sawtooth generator
Hello everyone,
Im using this ckt, its basically a sawtooth generator using a LM324. It works okay. my problem is that the ckt doesn't oscillate when i input 5,4,3,2,1 volts but its fine @ 6volts up to 15V. @ 5,4,3,2,1volts the ckt outs a DC voltage. Ive tried to use schottky diodes and reduced resistor values but still no progress/change.
So my last option is a change of opamp, got any suggestions on a op amp i could use preferably have the same pin configuration and can used running with only a single supply. Plz help
ichi
Hello everyone,
ichi
