Save currents in spectre
Shurik
Full Member level 3
Full Member level 3
Hello !!!
Can who offer decision of the problem?
I cannot save the currents of circuit in spectre of Affirma!
I select in "Save all" - save currents all !
On all the trys displayed of results in WaveScan, The CIW printed ->
astiCancelSelect(hiGetCurrentWindow())
*Warning* no "IT" data for node "/M0/D"
You can select the results you want to plot before the simulation...a roundabout way though!! Outputs>To be Plotted > Select on Schematic....would be better if u can send a snapshot oof the window though!!
try putting a 1u Ohm resistor and read the current from it , this happens a lot in spectre in some PDKs
Select >
Outputs>To be saved > Select on Schematic.
and save the wires u want ;)
you can put a vdc=0 which also means a shorted wire and measure current
