[SOLVED] Sar logic 2 clock sample pulse period hlep ???
wls
Member level 4
Member level 4
Singapore
Hello . I am trying to modify the existing sar logic controller as below so as to have sample pulse period of 2 clocks period but cannot ? I managed to make it work at rtl simulation but once running pre-gate lavel it cannot work ?
Can anyone help modify it to as give 2 clocks period delay for sample pulse ?
Attached also is the pdf from web that I used as example .
Thx.
// ADC controller
module controller(clk,go,valid,result, sample,value,cmp);
input clk; // clock input
input go; // go=1 to perform conversion
output valid; // valid=1 when conversion finished
output [7:0] result; // 8 bit result output
output sample; // to S&H circuit
output [7:0] value; // to DAC
input cmp; // from comparitor
reg [1:0] state; // current state in state machine
reg [7:0] mask; // bit to test in binary search
reg [7:0] result; // hold partially converted result
// state assignment
parameter sWait=0, sSample=1, sConv=2, sDone=3;
// synchronous design
always @(posedge clk) begin
if (!go) state <= sWait; // stop and reset if go=0
else case (state) // choose next state in state machine
sWait : state <= sSample;
sSample :
begin // start new conversion so
state <= sConv; // enter convert state next
mask <= 8’b10000000; // reset mask to MSB only
result <= 8’b0; // clear result
end
sConv :
begin
// set bit if comparitor indicates input larger than
// value currently under consideration, else leave bit clear
if (cmp) result <= result | mask;
// shift mask to try next bit next time
mask <= mask>>1;
// finished once LSB has been done
if (mask[0]) state <= sDone;
end
sDone :;
endcase
end
assign sample = state==sSample; // drive sample and hold
assign value = result | mask; // (result so far) OR (bit to try)
assign valid = state==sDone; // indicate when finished
endmodule
  • ADCcontroller.pdf
Do you want sample pulse has two clocks periods then comparison begins.
Or Do you want comparison begins after the fisrt clock period of sample?
In both case, you can try to understand how the comparison dures 8 cycles. You can use the same way yo have two clock cycle for sample.
Regars,
Jerome
Reactions: wls
    wls
