David_
Advanced Member level 2
Hello to you all.
I am going to use my first SAR ADC and I'm not sure if I should put this in the analog section or if its an appropriate topic for this part or not but please move it if it was wrong choice.
To the subject at hand, I have a ADC that has a input small-signal-bandwidth of 4MHz while only being able to output 200kSPS max. Apparently this allows it to capture high frequency transitions or transients through under-sampling which I need to read up on but that means that the op amp I need has to have >4MHz small-signal-bandwidth.
I have read a few pdf's about this subject but I can't extract any useful info through me failing to grasp what the are trying to convey with all equations and all.
The conversion time is 5µS for 200kSPS(4,8MHz SCLK 24clockCycles/conversion), I don't really know what data you/I need to tell but how do I derive suitable values for R and C to be put on the converter input to isolate the amplifier from the ADC?
And I guess anti-aliasing is a second purpose.
The acquisition time can be calculated as tACQ = 13(RS + RIN) x 35pF where: RIN = 800Ω and RS is the source resistance which needs to be below 1kΩ to not effect the ADC performance.
The application is for DC voltages but with a point to also reveal information about ripple voltage in the 20kHz range and also 50Hz/100Hz ripple if that would be present. I don't know quite what to aspect, there might not be any ripple for the ADC to handle but I want to allow for the design to process that kind of frequency's. Actually I want to allow for as much high frequency content as possible to be captured as long as that does not degrade the DC performance which is in the end the main application. The input capacitance of the ADC is typically 40pF.
Regards.
Regards.
