Sample C codes in HITECH compiler directory
gidimiz
Advanced Member level 1
Writing code in C
If you want to write code in C then you will have to use a compiler to compile to code to asambler.
If you will use the HITECH compiler, then go into the intalled directory and you will find there another directory called SAMPLES. in it you will find all kind of working samples in C code. you can read, copy past the code to your project and use it...
Good luck.
