Sallen Key Filter Question
newbie_hs
Full Member level 2
Full Member level 2
The below image is from LTC1966 datasheet.
May I know the use of RB
Mitigate bias current generated offset ?
I thought the same - at first.
But for bias compensation one would chose identical resistance for both inputs. Thus I expect: 38.3k + 169k = 207.3k.
294k seems a bit high.
Thus my second thought: maybe it uses the input capacitance to improve stability.
Sallen-key filters are known to be stability critical.
I don´t know
Klaus
LaTeX Commands Quick-Menu:
