eepty
Full Member level 2
Recently I noticed an accident that somebody put a stainless steel plate under a portable induction cooker. As a result the plate get heated and the heat melted the enclosure of the induction cooker severely.
I would like to ask is there any precaution on the product/electronics design on common induction cooker to prevent this case? A thermal fuse under the coil?
If not, is it possible to put a grounded metal wire mesh at the bottom of the cooker, to shield the magnetic field and prevent it heat up another metal underneath? (Using wire mesh because it will not build up an eddy current to heat up itself)
Thank you.
Thank you.
