Saber/Modelsim licensing problem
boondoggle
Newbie level 2
Newbie level 2
Somewhere in Minnesota
co-simulation saber/modelsim
Hello,
I've been trying to test out Saber's co-sim capabilities, but each time
I try to run a mixed-signal (spice + vhdl) example, Saber quits
with the following error message:
*** ERROR "SEC_NOT_AUTHORIZED" *** You need the "ModelSim"
package license to use Saber/ModelSim.
I'm running 2002.2 and the license file has a valid SABER_MODELSIM
feature. The Saber/Modelsim interface was installed (as far as
I can tell). I believe I've followed all the environment setup
instructions to the letter.
Any ideas on what's wrong/missing???
Thanks.
Dear all,
I encounter the same problem. I run Saber Designer and Modelsim, but I could not perform any co-simulation, even if the license feature Saber_modelsim is enabled. I assume it has to do with setting some general environment variables. The error message I get is:
*** ERROR "SEC_NOT_AUTHORIZED" *** You need the "ModelSim" package license to
use Saber/ModelSim.
As I have said, the license has this feature though....
Did anyone manage to to a Saber-Modelsim co-simulation out there?
may be changle the flexm server
Where do you get the license file?
Illegal request. You have been warned.
