ashuroks
Newbie level 6
I am stucked with my result of the design which i am preparing in HFSS
I am preparing an antenna which is 4 Arm Microstrip Spiral Antenna with 4 SMA feeds at 50 Ohms but since the impedance of antenna as theory says is not equivalent to 50 Ohms So i renormalize it to 300 Ohms Can you please check my design and let me know if there is any problem with my design of Antenna. If you also Calculate S parameter using Z parameter from the formula S11 = 20 log (Zin-Zo/Zin+Zo) Which is coming out to be wrong ..
I checked the results from the Solution Data by checking the Z-parameter and Zo but still i am not able to figure out where the error is
freq S-parameter Z-parameter Zo
Do not renomalize 1.9682GHz -2.58dB 527.66 +455.64j (49.755 +0.0248j) Ohms
Renormalize to 300 Ohms 1.9682GHz -15.8dB 527.66 + 455.64 (300+0j) Ohms
if using formula i backcheck the results like s11 = gamma = (Z-Zo)/(Z+Zo) then the results is not giving me the desired S-parameter Results .
I am not clear with what is happening here ?
I would be grateful if anyone can reply to this query
Thank your very much
