S parameter to Z parameter conversion
hrkhari
Full Member level 4
Full Member level 4
s parameter conversion
Hi Guys:
I would appreciate if you could direct me to any materials on the conversion of S parameter to Z parameter. Thanks in advance
Rgds
s to z parameter conversion
Here is a MATLAB routine I created to convert any 2 port parameter to any other.
s parameter to z parameter
you will find your answer in Pozar ch4 p199 if you have it
Reactions: trstlm
    V
    trstlm
s parameters to z parameters
Check the link below, it is a collection of Matlab routines for parameter transformation.
hxxp://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=6080&objectType=file
rgds,
Al
s parameters conversion
if you are using @DS .... then simply use the equation: Z=stoz(S)
s-parameter z-parameter
I know you can use Matlab, there is a RF Toolbox in Matlab and can simulate combine with Verilog-A
    V
