Elijah Jacobson
Newbie
I am a newbie in the RF field. I apologize for any stupid questions in advance.
I am working on a project in ADS and since the simulations gave me satisfactory results using ideal lumped components, I decided to replace these ideal components with commercially available models. So, I went to vendors' and manufacturers' sites and downloaded S parameter models for the components of my choice. Below is the snippet of circuit
I am trying to bring in the S parameter model for C41 1nf capacitor. I found a suitable component here at farnell. I went to manufacturer's website and downloaded the S parameter model here.
I have two questions.
1) The zip file downloaded has only series connection S parameter and as shown above, my capacitor is in parallel configuration in circuit. I cannot find shunt S parameters in website. Is it okay if I use the available series S parameters ?
2) Is there a difference between series and shunt S parameters ? if yes, can someone explain or lead me to a source where I can know more ? If there are no differences, then why does some manufacturer like Murata provide us with both shunt and series S parameters as seen here?
Now, since I did not have any other options, I took a leap of faith and imported the series S parameters for the capacitor and it changed the behavior of circuit in a bad way. So I am assuming that series and shunt S parameters are different. But I am not sure if this is happening because I am overlooking something or missing something. It will be nice to have an expert opinion on this.
Any help will be appreciated. Thank you very much for you time.
