s-parameter batch export from HFSS
snaildr
Junior Member level 2
Hi
Anyone knows how to export s-parameters from HFSS in batch mode? I swept a few design parameters and got a pile of s-parameters for different designs that I can use for circuit simulation, I feel exporting manually so many files is quite error-prone.
thanks,
Ran
"HFSS - Scripting" can be used to export S-Parameters automatically. First manually record the steps involved in exporting s-parameter to 'vb script file'. This can be done by selecting the menu item "Tools>Record Script to file". Created script file can be edited to export many set of solution data.
Or
In HFSS scripting Help, Example file to export S11 data is provided. This can be modified to accomplish the task. I am attaching same script for your convenience.
Hope this helps...
  • Export_S11.zip
Hi vinoth8051
Thanks so much for the reply! I was able to configure a script to do the batch export according to your description.
