tyassin
Advanced Member level 1
Hi
Maybe a trivial question....
I have an S-parameter file containing data for a three port balun. One input port is 50 ohm and the two output ports are 25 ohm.
I can see in the touchstone file from the vendor that it is measured in 50 ohm inviroment. BUT when I import the touchstone file in Designer I get the correct amplitude and phase balance and match at port 1. However the match at port two is very poor. COmpared to the datasheet the matching should be better that 15 dB at all ports but port 2 & 3 only give around 7-8 dB RL.
What is going wrong here...is it a setup problem in port impedance or what???
Thank you
Thank you
