kspalla said:This is good observation.
If you have simple structure let say microstrip transmiission lines then the substrate calculation is simple and you will come out quickly.
But if the structure is complex let say 16 layers of LTCC or 20 layers of different dielectric stackup then the momentum takes sufficient amount of time ( in tens of minutes to calculate the substrate function.
Just leave it and wait for completion of task.
Do not worry about that the system is not doing any thing. You can verify the same using the task manager
