Corliss
Newbie level 3
Hi everyone new to this forum, need a little guidance on a 12 volt converter made by "systems monitor inc" Here is the sequence of events I experienced with my RV. I installed some 12 volt LED bulbs in the fixtures, within the first hour of one being left on I returned to the RV to find the bulb I left on had exploded. First thought was to check polarity and voltage to the fixture. I found the fixture voltage to be 16.1 volts, I unplugged the RV from the 110 supply, remeasured the fixture voltage to find 13.1 this confirmed to me the converter to be the cause. I removed the converter from the RV, took the cover off to do a visual inspection, nothing burnt or obvious. I am assuming the voltage regulator is the culprit, a search of voltage regulators was confusing. Here is a photo of the converter if anyone can with direction or help I would appreciate it.
