Running scripts in Cadence SoC Encounter
miho
Junior Member level 3
Hello,
how can I run scripts in Cadence Soc Encounter? I'd like to perform the same steps on multiple designs to compare them. So I wrote a tcl script similar to the ones in the tutorial. But how can I execute them? specifying them with the -cmd option at startup didn't work. Just the usual Encounter window pos up but no design is loaded or anything else is performed.
Any Ideas?
u can use source command to runing the scripts in the unix cmd window
d'nt run script in command line for latest first time while checking.
run the script i gui mode inside the tool by step-by-step. so that u can debug it easly
