T
treez
Hello,
Our remote software engineer wants us to run some debug code on our controlled lighting system.
There is a problem with it and he says if we use the debugger it will help us diagnose where in the software its going wrong.
The micro is PIC18F26K20.
He says we should connect up to pin 14 (TX) and gnd at the micro.
We should then run wires from these pins to the USB port of a laptop.
He says we will also need a “serial data to file” program, and he says he uses “coolterm, so i guess we have to buy/download that?
Do you know what program we need to use to capture the debug data?...is it MPLAB IPE v3.26? ...he has written us the code that we need to load for the purpose....we loaded the hex file into the micro no problem, using pickit3.
However, what do we do next?
Do we need to set up MPLAB IPE in debug mode or something?
