Running ASITIC on Windows
aryajur
Advanced Member level 3
San Jose, USA
asitic_cygwin.exe
Hello,
I want to use ASITIC on a windows PC. I downloaded the setup file. Then I downloaded and installed Cygwin. Now when I run the asitic_cygwin.exe file it gives me the message:
This application has failed to start because cygX11-6.dll was not found. Re-installing the application may fix this problem.
What should I do to correct this? What all steps are re quired to use ASITIC??
Added after 47 minutes:
I could run ASITIC Finally, after I installed the X11 Libraries in Cygwin. But now the problem is ASITIC after asking the Technology file name gives a Fatal error and says that it could not open display.
I checked the XFREE86 libraries, they are no longer present in Cygwin. Is there any way over this problem??
