Rule to construct square constellation for the M-Array QAM?
Aya2002
Iraq
M-Array for QAM
Hi experts,
can someone help me to find the general rule to construct the square constellation for the M-Array QAM?
Thank you
M-Array for QAM
any help please?
Re: M-Array for QAM
I do not think there is one main rule. The numbering of points in the constellation depends on the specific code. Often used a pragmatic approach, google BICM, double Gray coding, etc.
    Aya2002
M-Array for QAM
thanks friend
M-Array for QAM
there are many rule here some:
1-the ratio between the bandwith of the channel of transmission and the data rate of the signal to transmit;
2-the ratio of signal to noise of the channel of transmission;
3-the data rate
