RST pin of N79E844AWG microcontroller
Dimpi
Junior Member level 1
HI,
Please tell me the circuit or hardware connections for reset pin of nuvoton N79E844AWG microcontroller??
Use this circuit...
Reactions: Dimpi
    Dimpi
Hey Dimpi
please go through this datasheet. it suggest to pull up the reset pin by 100 ohm resistor and connect a cap between reset pin and ground. Calculate your board reset time and use the cap accordingly.
http://download.nuvoton.com/Nuvoton...ember/DocumentsInfo.aspx?tp_GUID=DA00-N79E845
All the best...
helo ,
but seeing the datasheet how can we calculate the board reset time and what is its significance in finding out the value of capacitance.please elaborate??
Hi Mamuni
If the power goes off on your board and you need N79E844AWG to get reset after some milliseconds, then you will have to allow the capacitor to discharge slowly. so you may need a capacitor(C) of higher capacitance. This timing is always related with Controller(uC) reset time, the resistor(R) Value. for further clarifications, please see
https://en.wikipedia.org/wiki/RC_circuit
