ajit_nayak87
Member level 5
Dear all,
I have product which uses isolated and non isolated RS485 communication. I have issue with isolated design. I have used ADM2483 rs485 transceiver for communication. I have setup like this. by seeing this its obvious that unless i have 85-270vac aux supply i will have communication. since ground are different
i dont have issue with above setup. problem occurred when i introduce battery charging unit here. same 12v and ground are connected to 12V/gnd . i found communication has stopped . if i remove battery charging unit it started working again.
i have tried making communication ground of converter to secondary ground of adm2483 , but it didnt worked
i have tried using 100E termination resistor but it didnt worked.
my question over here is
1) if i wanted to make in all prospects means if i removed 85-270v ac primary connection also with 12V standby how can i make it work. usually how isolated design will work
2) weather for isolated design primary and secondary ground which are galvanized isolated can be made common??
3)Is there any article where above case i can implement??.
4) is there any alternate transceiver in non-isolated design which pin config is similar to adm2483
