RS232 to USB Converter Circuit Needed
HelderS
Junior Member level 3
PORTUGAL
rs232 to usb converter circuit
Hi, everybody!!!
I would like to implement a circuit wich can convert RS232, serial port to USB.
I've found at least one project, but it mainly used a module called USBmod1, wich it's too expensive,
So I would like to know if someone knows how to implement this kind of circuit, avoiding de expensive modules normally used.
Thanks, Helder Silva
cp2101 avr schematic
Try USB Complete By Jan Axelson ,it might be available in our forum ,you'll get the circuit there.
    HelderS
convert rs232 serial port to usb
you can use the silabs cp2102
it doesnt need external crystals, and its quite compact
there are drivers issues for linux, new drivers should be out 'now'.
schematic of eval board is self expl
// page 6 is the schematic
    HelderS
schematic converter rs232 ke usb
I thank you all, but all the circuits yu've told me, have only one problem, uses IC's wich are not easy to find (like the CP2102 or FT2232), where I live in, but... Thanks anyway, if any alternatives known, please don't wait to tell me, ok?
Thanks, everybody
Helder Silva
buy usbmod1 module
found this by accident
http://www.cesko.host.sk/IgorPlugUSB/IgorPlug-USB%20(AVR)_eng.htm
no idea if works
regards,
movingbait Ü
    HelderS
rs232to usb converter circuit
HelderS said:
Hi, everybody!!!
Just buy one, can save of the trouble.
    HelderS
serial to usb converter circuit linux
Yes glenjoy said is true, as USB to RS232 cost less then 7$. where as developing own PCB with components will cost more then 25$.
    HelderS
And you will also save your time writing the drivers also!!
Cheers
    HelderS
cp2102 circuit
i used the CP2101
great and simple chip to use
it is from silicone lab
serial to usb converter circuit diagram
michael alon said:
i used the CP2101
well i have a cp2101 too but i m facing problem to connect it, how did u connected ? do u have schematic, pcb etc ?
thx
simple com port to usb converter circuit
hi,
ful babu said:
michael alon said:
i used the CP2101
thx
See this link:
it only needs 3 capacitors as in the Example Circuit Diagram
If you found my answer useful, click on the button that says Helped me. ( NO points will be taken from you! )
Good luck.
