RS232<-->RS485 IC ?
SphinX
Advanced Member level 3
EGYPT
rs232 rs485 ic
Is there any single IC that performs RS232<-->RS485 conversion ?
Thanx
rs485 ic motorola
Please do not look at this answer as being sarcastic.
Have you looked at using a PIC or Motorola Nitron for this task?
Having seen the cost of UARTS for this, and they still need a micro anyway, might be best option as both companies supply a protocol stack for this anyway for free
rs232 to rs485 ic
Or you could use a Startech (Exar) UART like the ST16Cxx as they have 2 serial channels that can do 8/9 bit and clocked independent to each other, with or without FIFO
TI/MSC have same ideas.
All need 8 bit interface with Micro :cry:
rs485 ic rs232
Hi
Maxim MAX3160-3162
h**//www.maxim-ic.com/quick_view2.cfm?qv_pk=2318&ln=
* = t
rs485 ic model
if I'm not wrong max485 is IC for that (likemax232).
regards.
Mr.Cube
sipex sp485 maxim max485
SN75176 is easy to interface and i have used it.
Thanx
SphinX
max3160 pic
you can use SIPEX SP485
rs 485 ic
You can try this from TI sn65lbc184
also i think a chipt that convert from 232<<>> 485 will be expensive if avilabel
you can try two chip solution like Max232 + TI sn65lbc184
salam
best rs485 ic
If your problem is that you want to connect the COM port of a PC to a RS485 bus, you can use ADM-4000 series converter. Its isolated.
