RS232 interface in windows
s3034585
Full Member level 4
Full Member level 4
rs232interface
Hi Guys
I want to design a visual interface to interface Mod5282 to PC using rs232 port. This microcontroller has its own run time libraries which support rs232 communication. So i can write a small application on the microcontroller side. Now i want to develope a gui to controller the microcontroller. Its is basically for some testing of the pheripheral connected to the microcontroller.
Can any one pls tell what is the best point to start with. I dont know much about VC++ or VB. So can any one pls tell me which language would be best to start with. Are there any standard code for rs232 interface so that i can design my gui and relevant code which will translate into a particular command for the microcontroller.
Pls let me know
Thanks
Pritam
rs232 interface windows
You should probably use Visual Basic -- it is the simplest to learn. Also you find code available on internet ....
VB6 is easy but i recommend you to use Delphy with the comport control.
You can get Visual Basic or Visual C for free at
https://msdn2.microsoft.com/en-us/express/aa718406.aspx
Unfortunately Microsoft's support for the serial port has diminished and its features are not what they used to be with MSCOMM. I wrote an article on how to use the serial port in VB2005.net in Circuit Cellar 2006 (Issue 198) (there is a small charge to download it)
Scroll down until you see the title
Visual Basic 2005 and the Serial Port, by Aubrey Kagan
click on the pdf and then go to shopping cart.
There are also other versions of BASIC.
I have also worked with BBC Basic, which is available with serial port drivers and is also available for free in a limited version
https://www.cix.co.uk/~rrussell/bbcwin/bbcwin.html
Reactions: Holger
    Holger
If using DELPHI or C++BUILDER, I think the best way is to use Windows API, because the .exe file generated will not need some .dll, .ocx or other attached files.
It's visual basic.net and visual C++.net express edition that you can get for free from Microsoft website, not vb6.
hi . im oso doin a project in rs232
need the codes to control serial port
anione? or u hav it? visual basic
