[SOLVED] RPM sensors - help needed
J
JOkur
Newbie level 1
I have some fans that I want to monitor the RPM on... THe sensor I believe is called a HALL effect sensor. Where can I find them and some APP notes to use them...
THanks
Rich
check:
h**p://w*w.control.utoronto.ca/people/profs/francis/Ahmed_Ticku/WebPage/rrtc_hardware.htm
and download a pic program from this...
h**p://homepages.nildram.co.uk/~starbug/files/revcount.zip
best,
//a
Thanks for the links but.... I'm not looking for a PIC style sensor.
If you take apart a DC fan that has an rpm sensor, I am looking for something like that. Where I can take any old fan, hook up this circuit and be anle to monitor the fans rpm, from my mother board utilities.
If I recall correctly the sensor is called a HALL effect sensor. I found some of these but nothing that has an APP note I can look at.
Thanks
Rich
Take a look at w*w.allegromicro.com and you will find all the information you need about monolithic hall effect sensors.
Best regards,
Alexg
Working with just one hall sensor for small rpm is not very acurate if you want to update your display often.You have just one (1) impulse per revolution and for acurate controll it is not inough.Or you must have multipole magnet which is not easy to achieve.Better solution is optical.
Greetings
Dragan
<font size=-1>[ This Message was edited by: dragan on 2001-10-21 11:32 ]</font>
If it is one of optical is easier but if it is for production a multipole magnet is very cheap and hall sensors are much more reliable in the long term than optical sensors.
Best regards,
Alexg
