rpm not compile
ana_cont
Junior Member level 2
const wh_length=11;
const pulse=36;
const meter_pulse=(100/wh_length)*pulse;
int   meter=0;
char  speedshow[30];
char  RPMshow[30];
char  distanceshow[30];
int   count_puls=0;
int   speed ;
int   rpm=0;
void Interrupcion() iv 0x0004 ics ICS_AUTO
  if (INTF_bit==1)
    rpm = (1000/count_puls) * 60;
    speed = meter/count_puls;
  INTF_bit=0;
  if (TMR0IF_bit){
    TMR0IF_bit         = 0;
    TMR0  = 6;
    count_puls++;
  void InitTimer0(){
  OPTION_REG         = 0x81;
  TMR0               = 6;
  INTCON             = 0xA0;
void main()
UART1_Init(115200);
trisb.b0=1;
trisd=0;
InitTimer0();
   t1con=0;
   T1CKPS1_bit=0;
   T1CKPS0_bit=0;
  INTEDG_bit=1;
  INTF_bit=0;
  INTE_bit=1;
   GIE_bit=1;
  while (1)
    if (count_puls>=meter_pulse){
    meter++;
    count_puls=0;
    sprinti(speedshow,"n0.val=%d",speed);
    UART1_Write_Text(speedshow);
    UART1_Write(0XFF);
    UART1_Write(0XFF);
    UART1_Write(0XFF);
    sprinti(RPMshow,"n1.val=%d",RPM);
    UART1_Write_Text(RPMshow);
    UART1_Write(0XFF);
    UART1_Write(0XFF);
    UART1_Write(0XFF);
    sprinti(distanceshow,"n2.val=%d",meter);
    UART1_Write_Text(distanceshow);
    UART1_Write(0XFF);
    UART1_Write(0XFF);
    UART1_Write(0XFF);
If "not compile" is true, where's the error message?
Although the appropriate action is to encourage you to exercise a better elaboration on the question, I could not refrain myself to decipher the pieces of the question and guess that there could be an error in the syntax of the snippet below, where the uppercase variable RPM was not declared :
Good guess.
Presumed, this is the only syntax error in the code, there are unfortunately much more semantic errors that prevent the code from giving the expected output.
