Routing in zigbee in opnet
virajparab
Newbie level 1
Newbie level 1
Hello.
I am doing a project in zigbee in opnet modeller. i have 20 nodes, 5 routers and 1 coordinator. i have establish routing in such a way that if the end nodes want to send packets to coordiantor then the next hop should be a router. Where do you fom this network structure?
Hello dear fellows!
i m doing final year project on OPNET 14.5 using zigbee
technology ...i m new in this field....can anyone know about scenerio
creation based on cluster in opnet and then access source code of that
protocol ??? please help me..i'l be really really thankful to you
take care
Hi All, I am doing my resarch with opnet 14.5 modeller for zigbee.i create topology cluster with 3 coordinator,an every coordinator it has 4 end devices. After run the simulation for 3 minutes i am confused because i got the result for some nodes, data traffic sent is zero, please help me....Thanks
Hi all,
I am doing my project in opnet 15 using zigbee. I have previously worked in Opnet in the LAN but really confused about how the zigbee scenarios works. So totally confused about this. Can anyone please help me with some suggestions how to work.
Thanks,
Yazdi
Hi all,
i am doing a project in Zigbee using opnet 14.5 modeler. I am kind of new in this. How can i connect the end nodes with the coordinator, there is no default links available in Zigbee object palette. Can i use the 10baseT links??? please help.
sinha
Opnet 14.5 is outdated, you need to upgrade to their latest version.
Hi all, from my experience zigbee model in opnet has limitation for their network models.
every coordinators and routers can only have 2 end device. that's why some of the simulated nodes will not be able to participating the network.
i can help you
hello my friend
email:aghaeesaeed@ymail.com
this is my email,so you can tell me about your project,i hope i can help you
hi fellows!
can u provide me opnet modeler 14.5 licence i m very thakful to u , i m doing my research work i need opnet 14.5 licence
:-( plz contact me at annie_annie605@yahoo.com, plz i need some one help
can u provide me opnet modeler licence for 14.5 or 17.5. i m very thankful to u
hello friend
i have sent you by email.i hope can working.
