rizwanspirit
Member level 4
I have to power up an embedded server, which takes 5v, ~500mA. I made a 7805 regulator circuit, by using 47uf input and output capacitors, server initialized well but after some time it reboots.
I was told to increase the value of out put capacitor. By using 470uf 25v I/p and O/p capacitors, performance increased but still issue of rebooting was there.
Now i am using two parallel 470uf capacitors at output, the unusual thing i cannot understand is that sometimes output voltage climbs up slowly and after some time it reaches maximum level, say 11v (with 12v input to yhe circuit) and then jumps back to 5v.
I am unable to understand this phenominon.
I would appreciate if someone explain this, and clarify role of output capacitor.
