MARWEN007
Junior Member level 2
![Junior Member level 2](/styles/images/ranks/clevel2.gif)
I want to measure RMS voltage between points a (0.5) V and I rewrite a program in C to achieve my purpose may i know it does not work with me each time I simulate, I vary the amplitude of input signal to the peak I receive on an LCD value false efficient value
isis on my diagram is more than just a pic 16F877 connected with an LCD and a sine signal related to port A pin A1
frequency signal is 50Hz
I have tried this formula for calculation of trapezium numerical integral, exactly calculated the rms and this is my code
I hope someone passes a Glance
#include <16F877.h>
#device adc=8
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#include <math.h>
void main() {
const long N =3000 ;
long i;
int value;
float voltage;
setup_port_a( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 1 );
while(TRUE)
voltage = 0;
for(i=0; i<N; ++i)
value = Read_ADC();
voltage += (float)value*(float)value;
//voltage currently holds the sum of ADC values squared.
//to convert an ADC count to voltage -> ADC VALUE * (5 Volts)/(0xFF)
//0xFF is the resolution of the ADC.
//since ADC values are squared, for this routine:
// Voltage=ADC VALUE * (5 Volts)/(0xFF) * (5 Volts)/(0xFF) = ADC VALUE/2601 voltage /=2601.0;
voltage /=2601.0;
voltage = sqrt(voltage/(N));
printf("\r\nInput = %f V , voltage);
